disable isis restart-helper
Description
This command disables the IS-IS restart helper.
Syntax Description
Default
Enabled.
Usage Guidelines
When this feature is disabled, the router does not act as a restart helper and may time out a restarting router‘s adjacency per normal operation.
The following command disables the IS-IS restart helper:
Platform Availability
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
